1998 Jeep Cherokee Stalling
97,000 MILES • V8 • 4WD • AUTOMATIC
CRYPTKEEPER1305
what would cause my jeep to stall whenever i slow down to park or when i let off the gas? it also does it sometimes when i put it in reverse or drive.it doesnt stall when i'm driving,only when i'm almost stopped.
Feb 25, 2010 at 6:08 AM
JDL
  • 16,098 POSTS
Hi, how long since a tune-up? Have the trouble codes checked. Around here some of the national brand autostores used to check codes for free. Maybe the throttle-body needs cleaning. Idle-air system?
Feb 25, 2010 at 6:28 AM
CRYPTKEEPER1305
hi,thanks for the advice,i will try those things out.i did change the idle air control sensor,but that didnt do anything.i also got my codes checked out and it said i needed a input output speed sensor and i changed that as well.then i went back and got the codes checked again,and it still says i need a input output speed sensor,but i didnt think that would be causing it to stall and cant understand why it is still saying i need one.
Feb 26, 2010 at 1:36 AM
JDL
  • 16,098 POSTS
What was the actual code number? P0715 and P0720?
Feb 26, 2010 at 4:27 AM
