Monday, April 26th, 2010 AT 8:18 PM
I Have replaced electric fan/thermostat/upper lower hoses/sensor at thermostat/cooling fan sensor/water pump/serpentine belt/ I have no oil leaks/i flushed out radiator all directions no blockage/flushed motor/ if the motor temperature goes to 210 and you shut off motor it will not start until it cools to 180 then cranks ok motor turns ok but will not start until it reaches below 210 good spark and fuel but does not crank until below 210 never had problem before owned sense 1998 only had 36000 mile when bought I need help. I said nothing about a clunk it turns over fine it does not crank until it cools below 210
