Hi, Today I put the pressure gauge on before starting it. The fuel pump is working because I open the gas top and ask wife to turn key just to on and I can hear the pump for about 2 seconds. But we want to know what pressure it has. Ok with the jeep off and only on on position it read 44 I then started it to see if it goes on sure enough it crank on strong for like 12 minutes this time I left the gauge on and it had a steady number never got lower I snap the throttle to see if anything changes and it just went in between 44 to 50 stood flashing around there, I bang on the gas tank nothing change now I kept an eye on it to see if when it goes off does the pressure drop and since it didn't I said let me try the air condition on to see what happens well when I put the air condition on the jeep went right off but the pressure never change. Then I try starting it and it wouldn't start, it had a strong crank but won't start.
Then I got a new spark tester but I don't see any spark when I put on the wire and I ground it on a bolt that has no paint then I took the wire from the coil and try it and no spark I thought maybe I don't know how to use it so I put the my light tester that I own and put it in the wire boot and ground it to the negative battery side and crank it and no spark.
Yesterday it went off for no reason today it went off as soon as I put on the AC?
When I put the cam sensor it work fine for about a week before starting to go off on me when driving. First I put the new coil when it started stalling then I was told once the coil goes bad the cam sensor is next so when the jeep started stalling on me again I put a new cam sensor but it still the same?
I took a picture of the jeep with the gauge on so you can see it but can't find the wire to transfer to the PC.
Thanks.
Thursday, July 15th, 2010 AT 8:24 PM
