1998 Jeep Cherokee rough idle & engine dying occasional
141,000 MILES • 6 CYL • 4WD • AUTOMATIC
NITRODEMON61
engine stumbles and backfires,especially when cold,but will do this at any time or temp. some days it will run perfect all day long and then the next day act up.
Feb 20, 2009 at 9:43 AM
MERLIN2021
  • 17,250 POSTS
You can try a self-diagnostic test. To activate self diagnostic program:
With the ignition switch in the OFF position, depress the TRIP and RESET buttons.
While holding the TRIP and RESET button turn the ignition switch to the ON position.
Continue to hold the TRIP and RESET buttons until the word CODE appears in the odometer windows (about five seconds ) then release the buttons. If a problem exists, the system will display Diagnostic Trouble Codes (DTC's). If no problem exists, the code 999 (End Test) will momentarily appear.
Post all codes found.
Feb 20, 2009 at 11:16 PM
NITRODEMON61
there were no codes so i hooked up an actron auto scanner it also showed no stored codes over the past 6 months it has shown only 2 codes,with the actron, and they were misfire on cyl 1 and 2 its had a recent tune-up,plugs,cap,rotor and wires
Feb 21, 2009 at 4:48 AM
MERLIN2021
  • 17,250 POSTS
Well if it happens mostly when cold, you can try a new ECT(engine coolant temp) sensor. It acts as the "choke" for fuel injected vehicles. It's on the thermostat housing, and costs about twenty dollars.
https://images.2carpros.com/forum/automotive_pictures/62217_jeep_2.jpg
Feb 21, 2009 at 10:03 PM
NITRODEMON61
ok,all sensors are original.I changed the ECT sensor but no change. It really doesn't seem to matter what temp. the motor is,it's very random.When it does happen,if you floor it,itstraightens out almost immediately,but it can happen at any time,hot or cold.
Feb 23, 2009 at 5:01 PM
MERLIN2021
  • 17,250 POSTS
If it has backfired, it probably ruined the IAC, and backfires are a timing problem, or worn cam problem, possibly a bad CKP or CMP. Or weak fuel pump.
Feb 23, 2009 at 6:56 PM
NITRODEMON61
Ok,I changed the IAC it seemed to help but not fix it. What would you think would be my best next move? I actually got a code, it was misfire on cyl. 5. I also changed the valve cover gasket,it was leaking oil down the back of the engine. Should I check the injectors & if so how? THANK YOU for all your time.
Feb 28, 2009 at 4:39 PM
MERLIN2021
  • 17,250 POSTS
FUEL PRESSURE TEST Fuel Rail With Fuel Pressure Test Port 1. Release fuel pressure. See FUEL PRESSURE RELEASE. Remove test port cap. Install a 0-60 psi (0-4.2 kg/cm 2 ) fuel pressure gauge at test port. 2. Start engine and allow to idle. Fuel pressure should be 44.2-54.2 psi (3.1-3.7 kg/cm 2 ). If no fuel pressure exists, fuel pump relay control circuit may be defective. See TEST TC-101A, in TESTS W/CODES article. 3. If fuel pressure exceeds specification, fuel pump is okay, but fuel pressure regulator is defective. Release fuel pressure and replace fuel pump module. See REMOVE/INSTALL/OVERHAUL article. 4. If fuel pressure is okay, release fuel pressure. Remove test gauge hose. Install test port cap. Fuel Rail Without Fuel Pressure Test Port 1. Release fuel pressure. See FUEL PRESSURE RELEASE. Ensure area around fuel supply line and fuel rail are clean. Note direction of latch clip installation. Latch clip is located on top of fuel supply line at fuel rail. Using 2 screwdrivers, pry latch clip upward, and remove from fuel rail. 2. Pull fuel supply line from fuel rail. Install appropriate adapter into fuel rail. See FUEL RAIL ADAPTER APPLICATION table. Ensure adapter is fully seated in fuel rail. Install adapter latch clip into fuel rail, with latch clip fingers pointing downward. If latch clip will not fully seat so latch clip fingers extend downward below fitting on fuel rail, adapter may not be fully seated in fuel rail. FUEL RAIL ADAPTER APPLICATION 3. Connect fuel supply line to adapter. Ensure fuel supply line fully seats in adapter. Remove protective cap from adapter test port, and install a 0-60 psi (0-4.2 kg/cm 2 ) fuel pressure gauge at test port. 4. Start engine and allow to idle. Fuel pressure should be 44.2-54.2 psi (3.1-3.7 kg/cm 2 ). If no fuel pressure exists, fuel pump relay control circuit may be defective. See TEST TC-101A in, TESTS W/CODES article. 5. If fuel pressure exceeds specification, fuel pump is okay, but fuel pressure regulator is defective. Release fuel pressure and replace fuel pump module. See REMOVE/INSTALL/OVERHAUL NOTE: For additional information on fuel pressure and fuel pump testing procedures, see TEST NTC-5A and appropriate NS TEST in TESTS W/CODES article NOTE: All models are equipped with a mechanical fuel pressure regulator located in fuel tank, inside fuel pump module. Excess fuel is returned to tank through fuel pressurarticle. 6. If fuel pressure is okay, release fuel pressure. Remove latch clip. Remove test equipment. Before reinstalling fuel supply line, ensure fuel supply line fitting and fitting on fuel rail are clean. Lubricate fuel supply line fitting and fitting on fuel rail with engine oil. Install fuel supply line on fuel rail. 7. Install latch clip into fuel rail, with latch clip fingers pointing downward. Ensure latch clip is fully seated. Latch clip fingers should extend downward below fitting on fuel rail when fully seated. 8. Pull on fuel supply line to ensure fuel supply line is fully locked on fuel rail. Start engine and check for fuel leaks. Application Adapter No. 4.0L 6541
https://images.2carpros.com/forum/automotive_pictures/62217_jeepa_1.jpg
https://images.2carpros.com/forum/automotive_pictures/62217_jeep_3.jpg
Feb 28, 2009 at 10:45 PM
JHAMLIN
I had the same problem with my GC I replaced the throttle position sensor and was amazed. Are you also having problems with your overdrive?? if so I would say this is the problem. Sounds crazy but it fixed mine.
Mar 2, 2009 at 2:58 PM
