Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Jeep
Cherokee
Engine
Serpentine Belt
Pulley
1998 Jeep Cherokee Replacement of belt pulley
1998 JEEP CHEROKEE
224,747 MILES • 6 CYL • 4WD • AUTOMATIC
SUNNY132
MEMBER
1 POST
how do you loosen the belt to remove the pulley?
May 16, 2010 at 4:53 AM
Experienced Mechanic
If your tensioner is an auto temsionier, just turn it in the correct direction. Some require that you remove the retaining bolt in the center of the pulley and loosten it via a set screw.
May 20, 2010 at 2:54 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
