1998 Jeep Cherokee replaced crankshaft sensor
1998 JEEP CHEROKEE
215,000 MILES • 6 CYL • 4WD • AUTOMATIC
MIKEYAZ
i had the crankshaft sensor replaced on our grand cherokee because the car would not start it was running fine and then it just would not start at all one morning . now that the sensor has been replaced once it has warmed up it misses horriblely runs rough but runs fine until it has warmed up any suggestions?????
thank you
this ended up the water temp sensor was also bad i used information from this site to help me and as the car warmed up the temp gauge was fluctuating told the shop person they tested it and it registered 58 degrees when it was 210 causing it to run rich when it was warm
Dec 29, 2009 at 8:48 PM
  • 110,194 POSTS
THat is a common problem. I'm glad you got if fixed. THanks for using 2carpros.com
Jan 3, 2010 at 5:03 PM
