1998 Jeep Cherokee REPLACE MOTOR MOUNTS
1998 JEEP CHEROKEE
TUTTA40
Noises problem
1998 Jeep Cherokee All Wheel Drive Automatic
HOW IS THE EASIEST WAY TO REPLACE THE MOTOR MOUNTS IN '98 JEEP GRAND CHEROKEE
Feb 7, 2010 at 5:54 AM
  • 110,244 POSTS
Because you didn't list the engine, I will give you a general description.
Loosten the motor mount bolts and lift the engine to remove pressure from the mounts. Remove the bolts holding the mount to the engine and the frame and remove the mount. Reverse sequence to replace. NOTE: Do not lift the engine by placing a floor jack under the oil pan. Also, make sure the engine is secure before placing your hands anywhere they could get crushed if the engine would drop.
Feb 8, 2010 at 12:57 PM
