1998 Jeep Cherokee power to fuel pump
WGREELY
Electrical problem
1998 Jeep Cherokee 4 cyl Four Wheel Drive Automatic
no power to fuel pump after being hit from behind
updated 12/23/09
where is the fuel pump relay located
Dec 19, 2009 at 11:50 AM
  • 75,988 POSTS
If there's no power at dark green and white wire at the fuel pump connector-check and test the fuse no.21 15amp and fuel pump relay-if both okay could be a problem with the fuel pump control relay circuit of the computer.
Dec 19, 2009 at 12:01 PM
  • 75,988 POSTS
The fuel pump relay is in the power distribution center.
https://images.2carpros.com/forum/automotive_pictures/12900_fp_relay_15.jpg
Dec 23, 2009 at 9:36 AM
