1998 Jeep Cherokee Oil in water
1998 JEEP CHEROKEE
JERMY151
1998 Jeep Cherokee 4 cyl Two Wheel Drive
I had a cracked head and replaced it. I also changed the oil. After running it for10 minutes the oil became slightly milky. Could this be from bad oil/water that was still in the engine and I should just change the oil and filter again to see if it clears up? or could it be a deeper problem?
Oct 16, 2008 at 3:38 PM
JNOVACK
  • 723 POSTS
yes change the oil and see if it clears up if not start looking into it further
Oct 17, 2008 at 12:31 AM
