1998 Jeep Cherokee No Heat, what are the logical steps?
MARINER09
  • 1998 JEEP CHEROKEE
  • 6 CYL
  • 4WD
  • 145,000 MILES
My 98 Jeep Cherokee is only blowing cold air. The A/C compressor was replaced in the summer. I replaced the thermostat. When I switch the control from hot to cold, it certainly gets cold. When I turn it to hot, it doesn't get much warmer. What are the likely steps to find the fix? Is the heater core next? Relays?
Friday, November 21st, 2008 AT 6:18 PM
The thermostat been replaced-could be the air mix/blend/ mode doors problem -vacuum and actuators.
Friday, November 21st, 2008 AT 6:32 PM
TBDK87
  • 11 POSTS
How's you antifreeze level? If your low on coolant then the heat will become affected.
Tuesday, November 25th, 2008 AT 7:53 AM
