1998 Jeep Cherokee Little heat
OL VERNIE
  • 1998 JEEP CHEROKEE
Heater problem
1998 Jeep Cherokee 6 cyl Four Wheel Drive Automatic
I get very little heat from my heater even though the temp gauge is in the proper range leading me to believe I need to replace the thermostat. Where is the thermostat housing located on the 1998 4.0 liter V-6? Thank you.
Friday, December 11th, 2009 AT 1:49 AM
Check also the heater core if its clogged-up
Thermostat location: Very easy front center of the engine there is the thermostat housing where the top heater hose and top radiator hose come together. Remove this (2 or 3 bolts) and your thermo will come right out.
Friday, December 11th, 2009 AT 5:45 AM
