1998 Jeep Cherokee Loud popping
1998 JEEP CHEROKEE
147,000 MILES • 6 CYL • 4WD • AUTOMATIC
CANDACE915
I was wondering do you know what could be causing a loud popping noise when I turn? It sounds horrible. It also has started rattling when I am idling. Thank you so much!
May 11, 2009 at 7:56 AM
  • 110,244 POSTS
Check the front axle joints. They are most likely causing the popping. As far as the rattle, check the heat shield on the exhaust system. Many times a weld will break loose and cause it to rattle.
May 17, 2009 at 8:31 AM
