1998 Jeep Cherokee lights behind the instruments
150,000 MILES • 6 CYL • 4WD • AUTOMATIC
SNEHNESNE
the speedometer and rpm meter sit next to one another in my dash, and the bulb in between the two has burned out. it will not pass safety inspection this way, and i'd like to know how to replace it. thanks
Apr 10, 2009 at 8:58 AM
GHOSTRIDER8005
remove the front face of the daech board very simple a few screws and your done. then the guage pod has a few srews in it as well you will need to remove this as well so you can gain acess to the back of the cluster the lights are behind the cluster very small you can pick up these lights at any local auto shop if you ask them theycan find them or just go the stealership and buy some for about $20,000 dollars and heck since your there have them install them for a million or so. joking any ways its a pretty easy remove and install just be sure its the bulbs and not the wires sometimes electrical can be easyer than dismantling the dash board. hope this helps
Apr 11, 2009 at 1:12 PM
