1998 Jeep Cherokee hub bearing
TINO54
Suspension problem
1998 Jeep Cherokee V8 Four Wheel Drive Automatic
i've change hub bearing but the clicking noise continue
Jul 28, 2010 at 2:54 PM
RHOHL53
  • 8 POSTS
this noise comes from the brake pads having to much play on the spindle as you release the brake pads they move up and down causing a cliking noise remove the calipers and libricate the guides and spray brake quiet on the back of the pads and try ,if the problem continues then replace both spindles .
Jul 29, 2010 at 5:08 PM
