1998 Jeep Cherokee generic po720
1998 JEEP CHEROKEE
152,000 MILES • 6 CYL • 4WD • AUTOMATIC
EUGENE LENNY CARNES
I've changed the speed sensor, reset the computer and light comes back on after i reach 20 mph, is this a wheel sensor failure...?
May 5, 2010 at 2:05 PM
BLUELIGHTNIN6
  • 16,542 POSTS
it is indicating a faulty output speed sensor. is this the sensor you replaced or did you replace the input sensor?
May 5, 2010 at 2:10 PM
EUGENE LENNY CARNES
I replaced the speed sensor at the transmition ....
May 6, 2010 at 1:31 PM
BLUELIGHTNIN6
  • 16,542 POSTS
The output speed sensor in located on the left side(drivers side)at the rear of the tranmission. The input speed sensor is located in the front of the transmission on the left side as well as the vehicle speed sensor. Out of these 3 speed sensors, the code is showing a faulty Output sensor.
May 6, 2010 at 1:37 PM
EUGENE LENNY CARNES
yes that is what I changed, when I reset the code my engine light still comes on after i reach 20 mph..... the car seems to be responding better after I changed the sensor as far as shifting properly and running smoother.....
May 7, 2010 at 8:54 AM
