1998 Jeep Cherokee Crankshaft pulley
1998 JEEP CHEROKEE
SKRIMSKI
Engine Mechanical problem
1998 Jeep Cherokee 6 cyl Two Wheel Drive Automatic
I replaced the serpentine belt, but at the time I did not have a tensionometer for the belt, I started the engine and received a little rattling, so I shut it down and did an inspection and at the time found no abnormalities the belt was still tight and nothing loose was on the engine. So I restarted the engine and had metal to metal banging, upon closer inspection I found the crankshaft pulley gear had slipped forward off the crankshaft, what if anything can I do about it.
thx
Jun 9, 2010 at 10:46 AM
Try tightening the crankshaft pulley bolt to its flush and torque it to specs
Jun 9, 2010 at 11:42 AM
