1998 Jeep Cherokee brake fluid leak
165,000 MILES • 6 CYL • 4WD • AUTOMATIC
JKELLIOTT
there is a box above the rear axle, it has a steel plate over it, whenever the brake pedal is pushed a large stream of brake fluid sprays out
Apr 19, 2008 at 1:00 PM
BMRFIXIT
  • 19,053 POSTS
you need to replace a brake line
and then bleed the system
Your donations and the spread of your words keeps us going
Thank you
Jack
Apr 19, 2008 at 3:56 PM
