1998 Jeep Cherokee blown head gasket or head gasket is goin
1998 JEEP CHEROKEE
111,000 MILES • V8 • AWD • AUTOMATIC
CAJUNLAND504
  • 8 POSTS
I have a 1998 Grand Cherokee limited 5.2L .
I cant find out why I have a light knocking sound in the engine, and white smoke coming from the exhaust for 4 minutes after i start it up. I took the radiator cap off then started it , and fluid didn't shoot out, so I'm assuming its not a head. Plus the all fluids are fine, and they are the correct colors. I want to know if i use a head gasket sealer and that's not the problem , would it make it worse? Thanks.
May 19, 2010 at 10:48 AM
  • 31,937 POSTS
Hi there,
Head gasket sealers can cause other problems like blocking coolant passages and radiator cores, go get a head check done, this is a chemical test to detect exhaust gasses in the cooling system, this is a very accurate way of checking for a gasket problem, start here.
mark (mhpautos)
May 19, 2010 at 11:01 AM
