1997 Jeep Grand Cherokee no heat
AMC MAN
  • 1997 JEEP CHEROKEE
  • 6 CYL
  • 4WD
  • 180,000 MILES
Hello, I have a heating problem it runs around 200 on the temp gauge but blows cold air. I noticed that when starting to come up to temp it bubbles back thru the over flow tank and once the t stat opens it stops. The top and bottom rad. Hoses are hot but still blows cold it has never overheated as to say lost antifreeze all over the place. Once it is at temp and I shut it off the is a slight drip in the front of the engine behind the fan once in a while. Thanks for the help.
Sunday, December 23rd, 2007 AT 7:52 PM
SERVICE WRITER
  • 9,123 POSTS
What do the hoses going into and out of the heater core feel like?
Either it is plugged or the level is low is what I would suspect.
Sunday, December 23rd, 2007 AT 9:34 PM
AMC MAN
I FORGET TO CHECK THEM WILL CHECK IN AM. THE LEVEL IN THE TANK IS AT THE CORRECT MARK/. THANKS PAUL
Sunday, December 23rd, 2007 AT 9:43 PM
