1997 Jeep Cherokee Water pump leaking
120,000 MILES • 6 CYL • 4WD • AUTOMATIC
MARISAG
How much does it cost to replace myself, or how much for a mechanic.
Oct 27, 2009 at 2:23 PM
CHULEGAARD
  • 35 POSTS
$90 part, not too tough to do unless you have to remove the fan on the pulley. Make sure you get the gasket completely off the head or the new one will leak. Also use water pump gasket sealer on the water punp when you do it
Dec 9, 2009 at 9:28 AM
