1997 Jeep Cherokee u-joints / drive shaft
150,000 MILES • 6 CYL • 4WD • AUTOMATIC
PAUL C.
My rear u-joint failed ( trans to drive shaft) the yokes on both drive shaft and trans tail piece are chewed up. I need to replace drive shaft, looking for one from scrap yard . They need/ ask which rear end is in the Cherokee. How do I tell ?
Chrysler star is on rear end unit, but spicer name is stamped on drive shaft and trans. tail piece / yoke
Jun 20, 2008 at 4:35 AM
DOCFIXIT
  • 18,828 POSTS
Spicer is a third member type so if your diff has nuts and bolts on the side to shaft/tranny it's a spicer
If the bolts are on the back it is aC type ie Chry
Hope this helps
Jun 20, 2008 at 4:57 AM
LONESTAR5966
  • 16 POSTS
[quote:356263de1d="Paul C."]Drive Train Axles Bearings problem
1997 Jeep Cherokee 6 cyl Four Wheel Drive Automatic 150000 miles
Chrysler star is on rear end unit, but spicer name is stamped on drive shaft and trans. tail piece / yoke[/quote:356263de1d]
http://en.wikipedia.org/wiki/Jeep_Cherokee_%28XJ%29
Might help
Pick n pull or u-pull it I prefer Cheaper two
Jun 20, 2008 at 5:01 AM
