1997 Jeep Cherokee throttle position sensor
117,000 MILES • 6 CYL • 2WD • AUTOMATIC
BOBNULL
Grand Cherokee Limited
computer codes were 122 and 121 I replaced the sensor but check engine is still on and the jeep won't shift into overdrive. where else to look
May 24, 2008 at 3:56 AM
  • 75,988 POSTS
Throttle positon sensor signal is also use as an indication of the transmission throttle pressure to the computer-
Some vehicles the coolant temperature sensor is use as input signal to the computer to command overdrive-in a given temperature-
Did you check the circuit back to the computer for an open or short to ground.
May 24, 2008 at 4:18 AM
