1997 Jeep Cherokee shake
1997 JEEP CHEROKEE
BRIAN P FLYNN
Steering problem
1997 Jeep Cherokee 6 cyl Four Wheel Drive
it will start to shake at about 52 to 58 bad go to 60 or below 50 it will stop new universals in front drive shaft and axels tie rod and ball joint seem ok even rotated tires what else could it be help
Mar 8, 2010 at 1:27 AM
CJ MEDEVAC
  • 11,004 POSTS
See my profile
Alignment
Worn out steering components...tie rod ends etc.
Wheel bearings
Tires: Balance.........or........run hand Carefully around tire look for "GOOSE EGG" bulge on tire...(Broken belts in tire)....watch out for wire protrusions.
Someone SLIME your tire......fix a flat
BIGAS GLOB OF MUD ON INSIDE OF RIM
Love, Turddog
Mar 8, 2010 at 6:22 AM
