1997 Jeep Cherokee Radiator & Heater Core
DOWNTOWNHUMANOID
  • 1997 JEEP CHEROKEE
  • 6 CYL
  • 4WD
  • 208,000 MILES
My Jeep overheated on the highway and was POURING coolant. After getting it home, we noticed it was pouring out of the radiator. So, I bought a radiator and had a mechanic friend install. I also installed a new thermostat. After driving it home, it began to overheat again, and when I got out of the car and looked underneath I noticed it was leaking coolant again. Since we checked the pressure of the system, I knew it wasnt a leaky hose. But the coolant was leaking out of the overflow well. I have put so much coolant into the system, I wasnt sure if it was the system just bleeding itself out. At any rate, now I notice that the passenger floor is a bit damp. What is strange, is that I drove the car for several miles last nite and had NO PROBLEMS. No leaks. No overheating. Then a few hours later, I drove LITERALLY 1/4 mile and the car started to heat up quite quickly and the coolant was coming out of the overflow again. When I drove it back home, it did heat up quickly, but it doesnt want to overheat, it just stays at about 220. Which is about 5-10 degrees hotter than it normally runs. Is this an obvious heater core issue? Or is the car just bleeding air and the extra coolant? THANKS!
Tuesday, September 21st, 2010 AT 11:29 AM
CJ MEDEVAC
  • 11,005 POSTS
See my profile,
Imma CJ GUY.I answer alot of the CJ5s & CJ7s. Others too!
I do not know your rig, this is GENERIC!
Just gonna make a list!
1) Thermostat, even new ones, could be bad
2) Even a wonderful mechanic, might be jaw-jacking and put it in upside down. Or CELLPHONITIS!
3) the over-heat may have made a heater hose clamp leak (tighten). Thus water in floor
4) Heater core may be bad too!
5) Maybe your A/C drain is stopped up. Water on floor!
6) Heater core should not cause an overheat.'Less alot of water leaked out.
7) Did he refill the Radiator Fully? Run and refill it, after the thermostat opened?
8) I saw this, ONE TIME, Idiot routed his serpentine belt wrong. Water Pump turning backwards!
9) Doubt this is it, But Fan clutch bad, fan not turning enough.
Respond with good News,
The Medic
Tuesday, September 21st, 2010 AT 9:23 PM
