I have a 97 Jeep cherokee sport st. 6.
On Friday I parked it and did not move it till Monday. When I went to crank it it was hard to start. I had to hold the gas pedal down to get it started. Once started it ran really really ruff. If I let off the gas it would cut off. I replaced the plugs, wires, cap, button, and air filter. I also cleaned the throttle body and ran some sea foam through it. it ran great. or so I thought. If it is just idoling it does fine. But once you get in it and start driving, it starts acting up. As you are shifting through the gears it bucks really hard. It does it through all the gears. I cant really fig. out what is causing the bucking. it seems to be getting worse. It wont give a code. It it drivable but it will give you a neck ache if you drive for long. PLEASE help me. I would just replace parts but I cant afford that.
Jan 10, 2008 at 1:12 PM
