1997 Jeep Cherokee leaking in floor
250,000 MILES • V8 • AWD • AUTOMATIC
REDBANK1980
When I run my air conditioner it leaks in the passenger side floor. I had the heater coil replaced last winter. Only time it gets wet is when I run the AC.
Alos the air converter is stuck on the defrost setting. I cannot get it to blow out the bi level or floor.
Aug 9, 2010 at 2:19 PM
  • 75,988 POSTS
Leaking at the passenger side could be the AC drainage tube is clogged-up and backing it up. Stuck on defrost -you need to open it up could be binding or an actuator or vacuum problem
Aug 9, 2010 at 3:19 PM
