When I run my air conditioner it leaks in the passenger side floor. I had the heater coil replaced last winter. Only time it gets wet is when I run the AC.
Alos the air converter is stuck on the defrost setting. I cannot get it to blow out the bi level or floor.
SPONSORED LINKS
Monday, August 9th, 2010 AT 9:19 PM
MECHANIC
Leaking at the passenger side could be the AC drainage tube is clogged-up and backing it up. Stuck on defrost -you need to open it up could be binding or an actuator or vacuum problem
