1997 Jeep Cherokee IOD Fuse
160,000 MILES • 6 CYL • 4WD • AUTOMATIC
COURY
My IOD Fuse is blown. When I replace it with a 15 amp new fuse, it blows as soon as I touch the fuse prongs (legs, metal pieces, or whatever they're called) into the socket. What is wrong and how do I fix it. . . my interior lights, dashboard instruments (mph, tachometer, gas gauge, etc.), radio, etc. do not work. Please help.
Feb 15, 2009 at 8:19 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Has to be a short in the wiring. The list of circuits affected by the IOD usually consist of the following:
Cargo Lamp, CHMSL, Diagnostic Connector, Dome Lamp, Glove Box Lamp, Map Lamps, Power Mirrors, Radio, Under Hood Lamp
You may have to disconnect every one of these devices except including the OBD port to inspect their wiring.
Thanks for using 2CarPros.com!
Feb 15, 2009 at 10:28 AM
