1997 Jeep Cherokee Fuel pump fuse
1997 JEEP CHEROKEE
185,000 MILES • 6 CYL • 4WD • AUTOMATIC
MESCHMITZ
The fuel pump fuse has blown several times recently while driving. I checked the current draw at the fuse block and it's drawing just over 5 amps. The fuse is a 15 amp fuse.
Is there anything other than a defective fuel pump that could be causing this?
Haven't checked the filter, but pressure is good and there are no mil codes.
Oct 14, 2010 at 4:35 AM
JDL
  • 16,098 POSTS
If it blows randomly, may be hard to track issue. You have to test when the problem occurs. The fuse I looked at also supplies voltage to pcm. Any applicable mil codes? Fuel filter ok? Fuel pressure ok?
Oct 14, 2010 at 4:55 AM
