1997 Jeep Cherokee defroster
140,000 MILES • 6 CYL • 4WD • AUTOMATIC
LOISLANE
in summer I had drainage of the a/c in passenger front floorboards - now in winter my defrost barely works. What should I check and where can I find maintenance diagrams so I know where to look?
Dec 16, 2007 at 10:52 AM
MCQUE
  • 20 POSTS
You A/C cycles on and off when you run your defrost so that the humidity in the heated air is removed...
so if you are saying your A/C doesn't work, then that is probably why your defroster isn't working as well as you would like....
If you are saying you had/have a water leak under the dash, it may have affected the position andor operation of the blend door which mixes the A/C and Heated air circuit and routes it to your defroster...
Either way you probably need to to bring it to a shop.
If you feel you have the skills to tackle it yourself, you will need a Factory Service Manual at minimum to start, and then possibly some specialty tools to affect a repair.
Dec 17, 2007 at 2:07 PM
