1997 Jeep Cherokee Clueless
DFV
Engine Performance problem
1997 Jeep Cherokee 6 cyl Four Wheel Drive 160000 miles
The jeep belongs to my 18 yr old son. We have been told that 3 out of 6 ports on top of his engine were clogged. Do you have any suggestions. Would this cause it to run hot. Also, is it ok to drive without an oil pressure regulator (if you keep a close check on the oil.) Is the sole purpose of this device to give an accurate reading on the interior guage? Thanks in advance for any advice.
Dec 6, 2008 at 3:37 PM
JD20DOG
[quote:2b670f44e6="dfv"]Engine Performance problem
The jeep belongs to my 18 yr old son. We have been told that 3 out of 6 ports on top of his engine were clogged. Do you have any suggestions. Would this cause it to run hot. Also, is it ok to drive without an oil pressure regulator (if you keep a close check on the oil.) Is the sole purpose of this device to give an accurate reading on the interior guage? Thanks in advance for any advice.[/quote:2b670f44e6]
git some port cleaner and run better grade fueland an air filter.
oil pressure regulator tells you if your oil pump is out and is some thing that preferably should work.full oil dosn't mean a thing if your oil pump dosn't push it though the motor. a repair manual should help you a lot
Dec 9, 2008 at 4:15 AM
