1996 Jeep Cherokee WILL NOT SHIFT TO 4TH
MK1926
  • 1996 JEEP CHEROKEE
Transmission problem
1996 Jeep Cherokee 6 cyl Two Wheel Drive Manual
WHILE DRIVING CAN NOT SHIFT TO 4TH. GEAR, BUT WHEN PARKED I CAN SHIFT TO 4TH GEAR.
CHECKED TRANS OIL, LEVEL CORRECT.
THANK YOU
ML1926
Wednesday, November 18th, 2009 AT 11:15 AM
KHLOW2008
  • 41,814 POSTS
Hi MK1926,
Thank you for the donation.
Symptom indicates a bad 4th synchronizer hub or excessive clearance between the gear and hub. This could be due to worn synchronizer ring or a worn clutch shaft bearing and you would have to disassemble the trans to check/repair problem.
Monday, November 23rd, 2009 AT 8:00 AM
CHULEGAARD
  • 35 POSTS
It has to be in neutral to get into 4 low
Wednesday, December 9th, 2009 AT 5:11 PM
