1996 Jeep Cherokee Wet sensor problem
BLABLAB49
  • 5 POSTS
Transmission problem
1996 Jeep Cherokee 6 cyl Two Wheel Drive Automatic
Ok heres the problem. I put a new engine in my jeep and it ran good for about a month then the transmission would down shift to 3rd when i was driving at bout 45 to 55 and it wouldnt shift down or up and it only happens in wet weather.
Please help!!!!!!
96 jeep cherokee
straight 6
bout 190,000 miles on 4 speed trans
Dec 8, 2009 at 3:13 AM
CHULEGAARD
  • 35 POSTS
Check fluid in neutral, fill appropriately. Throttle position sensor will cause that shifting issue. Easy cheap fix
Dec 9, 2009 at 8:53 AM
BLABLAB49
  • 5 POSTS
[quote:13d0ed2a12="chulegaard@hotmail.com"]Check fluid in neutral, fill appropriately. Throttle position sensor will cause that shifting issue. Easy cheap fix[/quote:13d0ed2a12] the fluid is right and the throttle position sensor i changed it today and now it wont shift through the gears it stays in 1 gear no matter the rpms and it will go in reverse park neutral i dont know whats wrong now it was shifting when i parked it and i bought a brand new tps man please help this is my only means of transportation
Dec 10, 2009 at 11:19 AM
CHULEGAARD
  • 35 POSTS
Well I'm not sure what happened unless the connection broke when you replaced it. Coul have been a faulty part from the parts store. Weird I've changed those many times with success. I buy and sell these
Dec 10, 2009 at 11:28 AM
