1996 Jeep Cherokee water pump
110,000 MILES • 6 CYL • 2WD • MANUAL
SANDRAH
we have successfully replaced the water pum and all hoses conected. no more leaks. the engine heat light still came on. may that me the thermostat or is it possible that air is trapped. if so, is there a screw where the air can be let out??
Nov 13, 2008 at 7:43 AM
JNOVACK
  • 723 POSTS
if you squeeze lower hose you can work out most of the air and then fill radiator and the over flow tank and put caps on run engine let it cool and check th over flow fill as needed may take a few times but it will work the air out
Nov 14, 2008 at 10:22 AM
