1996 Jeep Cherokee thermostat water pump
1996 JEEP CHEROKEE
188,000 MILES • V8 • 4WD • AUTOMATIC
JOSE1995
where is the thermostst located on this jeeps motor?
Dec 11, 2009 at 1:42 AM
BLACKOP555
  • 10,386 POSTS
should be in the thermostat housing. follow the upper radiator hose to the engine. where it bolts on the engine is called the thermostat housing. remove the hose and the bolts and you should find the thermostat.
Dec 11, 2009 at 6:49 AM
