1996 Jeep Cherokee Starting Problem
95,000 MILES • 6 CYL • 4WD • AUTOMATIC
CORY COOK
Engine will start when cold and run and vehicle will drive until it gets hot. Then it will eventually lose power and cut off and hard to start again and it eventually does for awhile and cuts off again. Idles very low and cuts off after a few minutes. You have to keep foot on gas to keep it running to a point before it shuts off again.
Jan 26, 2009 at 6:04 AM
CRZYDRVR
  • 432 POSTS
have the fuel pressure checked. if there is not the proper amount of volume to supply what is needed vehicle will stall and be hard starting.
Feb 17, 2009 at 6:43 PM
