1996 Jeep Cherokee squealing noise
AZZHOEAMY
  • 1996 JEEP CHEROKEE
  • V8
  • 4WD
  • 180,000 MILES
I have a 96 jeep grand cherokee limited. I replaced the belt 5x the tensioner 2x and the idler pulley 2x and still has this noise. Checked all the pulleys and no noise from them. A guy from the parts store told me it was the bearings in the alternetor but I checked and no noise and the volts are correct. The last time I put the new belt on which is a gates now the noise went away for bout a day or two but came back. Never goes away from cold to hot.
Tuesday, January 27th, 2009 AT 11:32 PM
JIMZMENAME
Check you porer steering fluid level. Get one of those hand trigger type squirty bottles with some water in it and selectively spray a little on where the belt goes, this will at least eliminate the bely drive as a prob. But check power steering first
Friday, January 30th, 2009 AT 4:30 AM
JIMZMENAME
Jim is a poor typer
Friday, January 30th, 2009 AT 4:31 AM
AZZHOEAMY
Sprayed the belt with water noise went away but came back after water dried. Replace the belt 5x. Going to jeep dealer to get a new belt from them to see what happens
Friday, January 30th, 2009 AT 5:05 PM
