1996 Jeep Cherokee shakes violently
191,000 MILES • 6 CYL • 4WD • AUTOMATIC
REESEMAN
my jeep shakes violently when i drive over certain bumps like overpasses or some potholes but mostley over passes and i have to hit the brakes and slow down to a complete stop or close to it before the shaking stops. i thought it might be a broken motor mount or maybe the struts but my friend was in the car and said it didnt seem like the struts and it might be the uv joint or cv joint ?? i would just like to know what it could be before i take it to a shop or if its something me and friends can fix. i see your donation link above and i will look into that right now, i dont mind paying for a little piece of mind
Feb 20, 2008 at 6:46 PM
2CARPRO JACK
  • 11,533 POSTS
Sounds like a bad bushing or linkage in the front end. Without being able to inspect it, hard to say which one.Some Jeeps had issues with the front radius arm bushings
Feb 20, 2008 at 11:27 PM
BMRFIXIT
  • 19,053 POSTS
all I add is that we had a lot of brake rotor issues
I would have them check too
good luck
Feb 21, 2008 at 3:22 PM
