1996 Jeep Cherokee run car for a bout half hr and the car s
1996 JEEP CHEROKEE
186 MILES • 6 CYL • 4WD • AUTOMATIC
TMARIETTA
could it be i got a muffler and had a friend put it on if he put it on backward would that cause it to shut off
and something keeps draining my battery its not the
alternator i took it out and had it tested at autozone
Feb 26, 2010 at 11:52 AM
  • 110,240 POSTS
Here are the directions for checking for an electrical draw. It will help you locate what is killing your battery.
https://www.2carpros.com/first_things/why_is_my_car_battery_dead_over_night.htm
The muffler could cause the problem. Remove it and see if it then has more power. It could also be the catylatic converter. Check it when the engine is hot and running to see if it is red hot.
Finally, has the check engine light on?
Mar 4, 2010 at 2:18 AM
TMARIETTA
no check engine light and its not cherry red
Mar 4, 2010 at 2:35 AM
