I have the same problem that several others here have posted where the Jeep will start up like a champ sometimes, then I'll drive it 2 miles down the road, turn off the ignition and then it won't restart. The battery light goes on and the buzzer buzzes, but nothing happens. Then usually after a few minutes of turning the key, jostling the shifter, steering wheel, ignition switch, etc., it will randomly roar back to life when I turn the key again. The battery is fairly new and the connections seem good, no corrosion. What could it be?
Mar 16, 2009 at 5:33 AM
