1996 Jeep Cherokee Oil Pressure
RTITTERI
  • 1996 JEEP CHEROKEE
  • 6 CYL
  • 4WD
  • 11,600 MILES
Upon start the oil pressure gauge hesitates for a second, then reads about 40psi. Once running, the gauge flickers or bounces, and begins to drop. After a few minutes of driving between 20-40psi the gauge continues to flicker and drop, and drop significantly at idle (such as at a stop light). After several minutes of driving or stop/go traffic the gauge drops to 10-20 psi while on the throttle, and reads 0 at idle. If at idle and you tap the throttle, the gauge will jump and read 10-20 psi, then return to 0.
Dip stick reading is just below "safe" level, running 10W30, and there are just a few drops of oil on the pavement where I park.
Wednesday, October 13th, 2010 AT 10:28 PM
CJ MEDEVAC
  • 11,005 POSTS
If it were mine I would start out with a Mechanical Pressure Gauge to get a real accurate Pressure Test on the engine........not thru the electric way, like yours does now.
If I were NOT hearing Clatter and unusual noises from the engine
And did not have a guage to test with....................
I might invest about $20 for a sender......just to see if it were bad and causing the problem.
I did a little homework for you:
http://www.autozone.com/autozone/accessories/Performance/Gauge-Sender/_/N-269r?filterByKeyWord=oil+pressure+sender+&fromString=search
I hope it helps!
The Medic
Thursday, October 14th, 2010 AT 12:02 AM
