1999 Jeep Cherokee oil pressure gauge reading
EKNOWLSON
  • 1999 JEEP CHEROKEE
  • 6 CYL
  • 4WD
  • 140,000 MILES
My oil pressure gauge reading went down shortly after I started driving. The check gauge light came on. I continued driving and the pressure gauge went back up and the check gauge light turned off. I continued driving and the gauge went back down. The gauge continued to go down then back up. I drove all the way home like this, about 5 miles at 40 mph. My car did not overheat. I am just wondering what could be wrong?
Saturday, December 19th, 2009 AT 8:43 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for the donation
you need to check the oil level. Low oil will not cause overheating, it will simply cause damage to the internal parts of the engine. If the oil level is OK then suspect faulty oil pump
Saturday, December 19th, 2009 AT 9:50 PM
