1996 Jeep Cherokee grinding upon acceleration
147,000 MILES • 6 CYL • 2WD • AUTOMATIC
BAKEDFLOUNDER
Did you ever find out what the answer to the Jeep noise was? I have the same exact car, with the same exact problem.
Please reply, Thanks
Aug 8, 2008 at 11:43 AM
BLACKOP555
  • 10,386 POSTS
can you describe the problem to me if you would like me to help you, i dont know what your talking about.
Aug 8, 2008 at 1:50 PM
BAKEDFLOUNDER
the original post is this, and I have the same issue.
When my air conditioning/defrost is turned off, I have no problem. However, whenever either my A/C or defrost is on I have a problem. When I am idle everything is fine, A/C works great.
But whenever I ACCELERATE, push on the gas, and only when my A/C is on I get this loud sreeching noise from under the hood. When I shut A/C the sound stops immediately. Also stops if I take my foot off of the gas pedal!!
Aug 8, 2008 at 2:01 PM
BLACKOP555
  • 10,386 POSTS
sounds like the ac compressor is shot, probably a bad clutch or bearing, disconnect drive belt and turn ac on, does problem still appear? if not suspect the compressor.
is there metal shavings on it?
Aug 9, 2008 at 3:09 AM
