1996 Jeep Cherokee gauges
128,000 MILES • V8 • 4WD • AUTOMATIC
JAMESA87
My gauges continue to dim in and out when ever the parking lights or head lights are on. This also happens to my gauges for heat and a/c!
what could be causing this?
Feb 25, 2009 at 6:09 PM
  • 110,246 POSTS
Hi:
This could be a couple things. First, take the jeep to a nationally recognized parts store and have them test the alternator / voltage regulator to make sure it's putting out enough power. If it is, check for loose or corroded ground straps. I believe there is one from the transmission to the under carrage of the car which is a common problem.
Let me know what you find.
Feb 26, 2009 at 10:11 AM
