1996 Jeep Cherokee find and clean
102,000 MILES • V8 • 4WD • MANUAL
G FOOTE
could you tell me how to find the air control sensor, and also how to remove and clean? thanks
Apr 28, 2010 at 3:37 PM
BLUELIGHTNIN6
  • 16,542 POSTS
your vehicle uses an idle air control motor/valve and its on the throttle body assembly. you may try cleaning the TB assembly by removing and disassembling it then use carb-cleaner and small brush to scrub clean.
Apr 28, 2010 at 3:47 PM
