My Jeep will not start. Cranks all day, am not getting any fuel or spark. Ran fine to work after shift it would not start, first thought was fuel so i depressed shrader valve and turned key on and did not get any fuel. towed it home and checked the fuses and relay they were good. I took relay out and jumpered the pump and fuel began to flow seemed to be at a good flow and psi but did not have a guage on shrader. I than checked spark at spark plugs and had nothing dist, cap, & rotor are good. I need help what is next?
thank you
thank you
Jul 3, 2008 at 11:17 AM
