1996 Jeep Cherokee COOLANT MIXING IN OIL
1996 JEEP CHEROKEE
100,000 MILES • V8 • AWD • AUTOMATIC
CARLOS FERREIRA
STOPED ENGINE FOR 1HOUR GOT BACK IN SWITCHED IGNITION KEY ON -MESSAGE LOW COOLANT-FILLED COOLANT DROVE 2KM SAME MESSAGE-TOOK TO MECHANIC -TOLD IT WAS HEAD GASKET-HEADS OFF-HEADS DONE NEW GASKETS-SAME PROBLEM-BACK TO MECH-TOLD IT MUST BE CRACKED BLOCK-ENGINE OUT PRESSURE TESTED-NO CRACKS-NEW RINGS -PISTONS GLAZED-BLOCK RE-SLEEVED ALL 8 CILINDERS NEW BIG AND SMALL ENDS-SAME PROBLEM-BACK TO MECH-TOLD IT MUST BE INTAKE MANIFOLD CRACKED-MANIFOLD OUT PRESSURE AND UV TESTED NO FAULT-RE-ASEMBLED NEW GASKET SET AS PER MANUAL-3MONTHS DOWN THE LINE-ALMOST NEW MOTOR-GUESS WHAT SAME PROBLEM-I WILL DRIVE THE CAR FOR TEST DRIVE 100KM NO PROBLEMS COOLANT FULL OIL FULL GET BACK STOP THE CAR CHECK BOTH ALL OK, 20 MINUTES LATER THERE IS NO COOLANT IN RESERVOIR AND OIL DIPSTICK IS MILKY (OIL AND WATER) PLEASE ANY CLUES
Apr 19, 2010 at 7:40 AM
CJ MEDEVAC
  • 11,004 POSTS
See my profile, I do not know your rig, but do understand automotive machine technology to a medium extent.
Is your mechanic certified? (or really knows his stuff)
Did you have your heads tested for warpage?
Were they resurfaced?
Torqued to specs and in sequence?
Respond?
Love, Turddog
Apr 19, 2010 at 12:37 PM
LEGITIMATE007
  • 5,121 POSTS
check the cooling lines as they run through the radiator..change low coolant sensor
Apr 20, 2010 at 4:27 AM
