1996 Jeep Cherokee broken part
95,000 MILES • 6 CYL • 2WD • AUTOMATIC
BVMO
removed defective neutral safety switch. have a new switch, however, the old switch was extremely difficult to remove. finally out, but the stop behind the big bolt thread or whatever its named, is broken. probably about 1/4 of it is out. Now I have no idea what to do. replacing the switch is no problem, however, I don't know what I must do about the broken stop (or whatever it is).
Dec 12, 2007 at 1:00 PM
2CARPRO JACK
  • 11,533 POSTS
Any chance of getting a pic posted? I cant find a good picture of the trans to see what you are talking about
Dec 12, 2007 at 11:23 PM
BVMO
the shaft where the switch fits and is secured by the tabbed washer and attaching nut. at the base of the attaching nut threads there is what I believe is the oil seal. This seal (or even if its not an oil seal} needs to be replaced. It was busted or broken during removal. I looked on alldata and and it appears to me that the shaft is the manual valve shaft. It shows a picture of the manual valve shaft and the broken part. I'm just not sure if I am looking at the correct item....Only the oil seal or whatever it is needs to be replaced. It was broken during removal.
Dec 13, 2007 at 12:26 AM
2CARPRO JACK
  • 11,533 POSTS
Im thinking your best bet will be to go to the local parts house and have them bring up a pic of the seals for the shift shaft and see if it is right
Dec 13, 2007 at 1:35 AM
