1996 Jeep Cherokee backfires thru air intake
1996 JEEP CHEROKEE
209,060 MILES • 6 CYL • 2WD • AUTOMATIC
TINKER12121972
it doesnt do it all the time off and on
Jan 7, 2010 at 6:00 PM
  • CAR REPAIR CONTRIBUTOR
  • 110,190 POSTS
Has the check engine light me on?
Jan 7, 2010 at 9:26 PM
TINKER12121972
no its not and its getting worse also it has air in the lines when i push the valve i dont know what its called air comes out then gas then it cranks again
Jan 8, 2010 at 9:32 PM
  • 110,190 POSTS
Can you take a picture of the valve you are refering to and where the air then gas is coming out? I'm not exactly sure what part you are refering to. Also, if the check engine light hasn't come on, chances are it is fuel related.
Jan 8, 2010 at 11:20 PM
TINKER12121972
Thanks for the info but we finially got it running right it was the fuel pump and a bare wire coming off of the coil and a wire someonr put in the starter relay box. its running great now we bought a book and its amazing how much it helped us it was worth the 26.00 for a repair manuel
Jan 14, 2010 at 11:09 AM
  • 110,190 POSTS
I'm glad to hear you got it going. If you have questions in the future, let us know, and thanks for using 2carpros.com.
Jan 14, 2010 at 3:55 PM
