1996 Jeep Cherokee Axle Gears
1996 JEEP CHEROKEE
KJOBES
Drive Train Axles Bearings problem
1996 Jeep Cherokee Four Wheel Drive Manual 148000 miles
The spider gears went on my rear. I ordered them from Morris 4x4 but they only had 9 teeth and mine have 11. I called and gave them my vin number and they said I have a chrysler 8 1/4 and that is the correct gear set so someone changed the rear. I have owned it since new and never changed it out. Please let me know what I have and where I can get the gears? It has 10 bolts and a flat bottom. The tag says it has a 3.07 ratio.Thank you.
Aug 3, 2010 at 5:12 AM
2CARPRO JACK
  • 11,533 POSTS
I looked through some Jeep forums and it looks like they either had the Chrysler diff or a Dana 35, the CJs had Dana 44s.You may want to check out the Dana spiders to see if they are the right ones.
Aug 4, 2010 at 1:32 AM
